Minimal small recording indicator next to cursor
I really like what VoiceInk does with UI in the MacBook webcam notch, the UI just slides in and out of view without getting in the way
Hey, Dale. Have you tried the collapsed version of superwhisper? It's pretty similar to the Voice Ink implementation.
I like this! It's not that important but would make a nice little UX improvement.
Released in v1.15.2
I am adding an option to hide it, for now. Issues with this configuration are: - Real-time dictation feedback is not possible without the window (cannot accomplish this within the text field of any app) - LLM modification of output will also not be possible without a window This is going to be core functionality and the reason why you would choose superwhisper over an alternative, though I understand the desire to not have a window. I will also be adding an "automatically close window after processing is complete" option. Which will be more likely to never be removed.
Update from macOS (Superwhisper 2.19.0, macOS 15): a mini window pill now exists and seems to cover this request. But it stays on screen permanently, and after each dictation a text bubble with the transcription pops up above it. I can't find any setting to hide either of them ("Always close" doesn't remove the bubble, and the pill's right-click menu has only Expand window / Open Settings / Open History). It would be great to have an option for a truly minimal mode: e.g. show the indicator only while recording, and let users turn off the transcription bubble and rely on audio cues.
